403 Continental Pistons and Sleeves needed
D.Edwards
09-15-2002 12:12:00
I have read that the 403 used in the LA Case was a large bore version of the J-382 Continental. I am looking for good useable pistons and sleeves for this motor.
thanks
dnedwards@willmar.com
CP
09-15-2002 14:53:45
 Re: 403 Continental Pistons and Sleeves needed in reply to D.Edwards, 09-15-2002 12:12:00
Hey I am not sure if what you are looking for is the same as a LA case. Cont. made a J382 and a JD 382 diesel and they made a JD 403 diesel for mostly military applications. I have never seen a 403 gas engine. The 403 used the same crank as a 382 but a 1/4 +/- different bore. And also depending on the application and RPM some 382 and 403 engines had a ballance shaft and the slower RPM engines like the Massey 55 didn't use one. Case used a JD 382 in a Case 1000 crawler. I have never seen case use a gas J 382.
