Case 442 transmission problems
Steve D.
09-18-2002 19:35:39
Hi Case fans! Sorry, I'm into Bolens garden tractors and I know NOTHING about Case tractors. However, my neighbor just purchased a fairly large compact tractor made by Case. It is model number 442. This thing has huge rear tires/wheel weights/chains and it looks like it will REALLY plow some snow!!! Anyway, they think it has a problem with the hydrostatic transmission/transaxle. It seems that it won't stay still once parked, just wants to roll away. Whats up with that? If you have any expierence with something like this, please reply or email me directly at sdreibelbi@aol.com. THANKS
Max
09-18-2002 20:31:59
 Re: Case 442 transmission problems in reply to Steve D., 09-18-2002 19:35:39
Just needs the parking brake set. The hydraulic motor on these turns over fairly easy and this model didn't have the hydraulic lock feature like some of the earlier models. As long as the unit pulls good, it should be ok. Sometimes I forget to take my 446 out of gear and push it out of the way. Careful on adjusting the brake band for there is a fine line where the brakes are under adjusted and over adjusted.
