Case DC will not move.
Rick
09-19-2002 06:50:37
I have power going to the pto and belt pulley but not to the wheels. I can get it into all gears so transsmision is working. I was pulling hard untill a loud snap sound then that was it. Rick
Tractor Man
09-20-2002 06:44:11
 Re: Case DC will not move. in reply to Rick, 09-19-2002 06:50:37
It sounds like you have broken a final drive chain or drive shaft.
Don L.
09-19-2002 08:23:28
Check and see if you have broken a large drive chain....
Don L.
klyde
09-19-2002 09:47:31
 Re: Re: Case DC will not move. in reply to Don L., 09-19-2002 08:23:28
and the easy way to tell is to step on one brake and then the other... if it moves when the right brake is on , then the right chain is broken and viseversa
Duner Wi
09-19-2002 19:43:00
 Re: Re: Re: Case DC will not move. in reply to klyde, 09-19-2002 09:47:31
If the drive chain is broken some times you can break more stuff by towing it as the chain wads up under the sprocket and you now have a hole in the bottom of your tractor.
