970 power shift transmisson problem
Rick
09-21-2002 19:30:27
Our 970 with power shift won't pull it's self in range 1 and makes a loud squeeling noise. Does anyone have any idea with the problem might be? Thanks in advance. Rick
david
09-25-2002 08:03:51
 Re: 970 power shift transmisson problem in reply to Rick, 09-21-2002 19:30:27
Try pulling the shift valve body, disassemble, and clean. Make sure to follow the shop manuel exactly as there are some settings that if you change are major $$ to get fixed. I had a little piece of dirt hung in mine on a 2090. Case wanted $10,000 to rebuild the whole powershift unit. I sold it to a friend for $4500 for him to use as a stationary powerplant. He took the valve apart and put less than $300.00 into it and it's worked fine for another 1500 hours.
david
09-25-2002 08:03:41
Zach
09-21-2002 21:40:41
what about the other gears??? clutches might be bad but i don't know if that would make it squeal wonder if the hyd pump is junk
rick
09-22-2002 13:57:46
 Re: Re: 970 power shift transmisson problem in reply to Zach, 09-21-2002 21:40:41
Zach,Second ranger will pull but doesn't seem to be right, third range seems O.K.
