Case 580ck 188gas backhoe with shuttle.
doug
09-22-2002 21:02:47
wont pull itself when warmed up. changed fluid and filter, flushed with fuel oil, trans pressure stays in green when in neutral, but drops off when placed in gear. seems to have more power in reverse than forward. i also hear a screaming? aereated fluid type noise from the steel lines that go forward to the trans filter by radiator. took filter completely out, no change. i bought this backhoe not running so dont know what prior symptoms were. now i have a rebuilt engine in it, and this happens.... i could have dug the holes i needed with a shovel and saved time and m oney! thanks for any advice or encouragement...
