530 CK Hydralics
RogerM
09-27-2002 06:42:04
Does anyone know how to check and adjust the hydralic pressure on 530 CK? This is a loader and backhoe unit, with the pump mounted in front of the crankshaft. The high pressure line goes to the loader valve.
DaleIN
09-27-2002 07:48:45
 Re: 530 CK Hydralics in reply to RogerM, 09-27-2002 06:42:04
Hi Roger,
Plumb a gauge into the 1/4 pipe plug on the outside of the loader control valve. With the oil warm, raise a stab leg all of the way up and hold it. I don't remember the exact spec, but it should be somewhere around 2000 psi. Of course, a pressure gauge alone won't always tell the whole story, since worn hydraulic pumps can sometimes still supply pressure at low or 0 flow.
The main relief pressure is adjusted by removing the acorn nut on the rear of the loader valve, and screwing the stud in to increase pressure. But, be careful, this doesn't often work, since it is rarely set too low. Its more often already screwed in too far (in a futile attempt to correct another problem, like a weak pump or worn relief valve). Or, if JUST the hoe is weak, a blown power beyond Oring or cracked pb sleeve is usually the place to start looking.
