2090 case 540 P.T.O.
Rob
09-30-2002 08:00:25
I have sheared the 1/4" key on the 540 pto twice. is this a weak spot on the 2090's and if so is there a fix to it. It is a relatively cheap repair but a real pain getting to it each time. Thanks for the advice.
Kase
10-01-2002 03:52:12
 Re: 2090 case 540 P.T.O. in reply to Rob, 09-30-2002 08:00:25
You must have a early 2090. Case had a updated a changed the key way to i belive around 3/8s this will stop your problem. You have to change the gear and shaft and is very exspensive thru case.
