1390 case hyd. heat poor lift
Donnie Gaines
10-01-2002 13:58:53
have a 1390 case after about 1hour bushhoging the trans case is extremly hot you cant touch it. it has twin front pumps i have put new seals in them, changed both suction and pressure filter, new oil and it still gets hot. any ideas i have no clue where to go next. Thank You
Jimc
10-03-2002 08:55:30
 Re: 1390 case hyd. heat poor lift in reply to Donnie Gaines, 10-01-2002 13:58:53
Hi I remember ploughing and discing with DB 990`s and 995 before the days of Q cabs. And the transmission used to get so hot it could burn your hand and on one occassion i melted a hole in my Nora wellington boots. The temp went up under heavy traction and was quite normal. Hope this answers your question. Regards Jimc
Jeb Mccranie
10-02-2002 16:33:02
My 1290 used to do the same thing. Turned out to be the clutch. Used to get so hot your shoes would stick to the tractor.
Elmer
10-01-2002 18:33:45
Check your 3 point hitch raise lever. Raise it all the way up and listen to see if the hitch system goes on relief. Inch it ahead to see if it quietens out. You may have the control valve assembly relief valve creating the heat. Watch your tach and see if the rpm changes when you move the lever ahead from full back position.
