530 ck hydraulic problem, PLEASE HELP!
John
10-04-2002 19:17:28
when I lift the loader on my 530 ck everything is ok but when I move the bucket lever the main oil seal on the pump pops out and dumps all the oil, can anyone help me? thanks.
jeff
10-09-2002 12:39:05
 Re: 530 ck hydraulic problem, PLEASE HELP! in reply to John, 10-04-2002 19:17:28
what is the model of the loader? and did it have a backhoe originally?
JEAN CLAUDE MARLEAU
10-04-2002 20:02:41
HI JOHN FROM MY PAST EXPERIENCE I GUESS YOUR HYDRAULIC PUMP IS DONE THESE PUMP ARE WHITE MEDTAL AND THEY LAST IN BETWEEN 3500HOURS AND 4000 THEREAFTER IF IT BLOWS THE SEAL ON THE END USUALLY THE REAL CAUSE IS BECAUSE OF THE WEAR IT IS BUILDING THE PRESSURE IN THE PUMP INSTEAD OF IN THE SYSTEM THOSE PUMP ARE NOT EXPENSIVE YOU CAN PUT A DR41390 PUMP FROM YOUR CASE DEALER HERE IN CANADA IT IS ABOUT 295.00 EXCHANGE. HOPE THIS WILL HELP YOU
John
10-06-2002 12:40:01
 Re: Re: 530 ck hydraulic problem, PLEASE HELP! in reply to JEAN CLAUDE MARLEAU, 10-04-2002 20:02:41
That's what I was thinking so the pump has already been replaced. Anyone else have an idea what could be wrong? Thaks John
gm
10-06-2002 19:38:34
 Re: Re: Re: 530 ck hydraulic problem, PLEASE HELP! in reply to John, 10-06-2002 12:40:01
maybe disconnect the bucket cylinders and
try to move them manually. If its only doing
it for that lever, perhaps the cylinders
are sticking for some reason. Also, maybe
your pressure relief valve is not working
properly.
-Greg
