Blockage...So dismantling a DC-4 Rocker Arm Info needed?
Greg
10-05-2002 14:19:58
Greetings
Had louder than usual valve noise so I pulled the valve cover to take a peak. When the engine is running a RIVER of oil is coming out of the rocker arm cups for cylinders three and four,, and wahsing down by the push rods...
It is also coming out of the bottom of the rocker tee and running down the outside of the tube that supplies it.
Here's the problem, very little oil seems to be reaching the tappits for the for front two cylinders( the very occasional drop, the furthest tappet doesn't seem to be getting any...I watched for about five minutes).
Am I right in assuming that there may be a blockage?
If so, I assume that undoing the 4 bolts will allow the rocker arm to be removed.
HOW DO YOU GET THE OIL SUPPLY TUBE OFF? Once off. should I soak the arm in kerosene or use compressed air?
ANY OTHER HELPFUL HINTS?
ANY information would be a great help.
Thanks.
Greg
Nedd
10-07-2002 10:15:49
 Re: Blockage...So dismantling a DC-4 Rocker Arm Info needed? in reply to Greg, 10-05-2002 14:19:58
You shouldn't have to remove the whole assembly, if you just loosen the four nuts that hold the rocker arms down. Then take a good pliers or vise grip and turn the tube/shaft that holds the rocker arms. This will help restrict the oil flow to the back and may open up the blockage to the front. Hope this helps.
