Case SC Govenor
Joel
10-10-2002 06:06:39
Hello all! I have a problem with a SC that I just got running. It either idles or runs full speed. Nothing in between. Would this be a govenor problem? Does'nt seem to activate under load at full speed. And if so, does the whole front need to come off? The cover is all one piece. Or is there a way to access it through the housing where the mag attachs to? Parts availability??
klyde
10-10-2002 09:48:22
 Re: Case SC Govenor in reply to Joel, 10-10-2002 06:06:39
you can pull it out from the back---make sure you mark your timing first or you'll have a fun time retiming. Dont know about parts.
PS has govonor sping been replaced with somthing else????
Joel
10-10-2002 11:16:44
 Re: Re: Case SC Govenor in reply to klyde, 10-10-2002 09:48:22
Nope. The spring is original epuipment. Nothing has been altered.
