900 Injector pump
DeeCill
10-10-2002 17:03:34
I have a Case 900 built in 1957 I need to know
how to turn UP the injector pump the pump is
a American Bosch. I need more power out of this
tractor.Can this pump be TURNED UP or do I look
for somthing to replace it? Thank's for ENY help.
Yes it is possible
10-11-2002 21:59:59
 Re: 900 Injector pump in reply to DeeCill, 10-10-2002 17:03:34
take the rectangular cover off of the top rear of the pump. There is an arm in there that moves against a stop that is adjustable by loosening the two bolts and sliding it front(more fuel)and back(less). also on the top of the arm there is a small part that can be rotated up and down. this changes where the arm hits the slanted stop at a given RPM. By adjusting these two things you can change the power curve of the motor. Don't get too carried away though too much fuel doesn't do you any good.( all you need is a 7/16" Wrench)
sam the case man
10-10-2002 19:20:48
DON'T, all you will do is make it smoke and use more fuel! not gain much HP.
Zach
10-13-2002 13:07:53
 Re: Re: 900 Injector pump in reply to sam the case man, 10-10-2002 19:20:48
Our 1070 is turning 140 hp and its turned up but also has a turbo but turning it up will help some till you get to carried away.
DeeCill to Dust
10-11-2002 12:58:31
So,what is the answer to making more power from
the 900,change HEADS and INJECTOR pump.
I DON'T WANT TO TURBO IT.
If I put a bigger Bore in,will this pump supply
enough Fuel? I Have 100 questions so it SEEMS. THANK YOU.
caseman-d
10-10-2002 20:02:15
Heck I gotta get mine to smoke first, has 23.1-26 rears and it seems to just power out in the 10,500 lb class. I know it's weak but should still smoke some.
caseman-d
caseman-d
10-10-2002 17:37:48
I have a 57 Case 900 to so if you find anything out hope you'll share it. You should have the rotary injecton pump, not the inline pump correct?
caseman-d
DeeCill
10-10-2002 17:55:49
 Re: Re: 900 Injector pump in reply to caseman-d, 10-10-2002 17:37:48
YES
