Case 530 CK Loader
RogerM
10-10-2002 17:52:32
On a 530 CK loader there are two cylinders for tilt, two to raise and lower the loader and one on the right hand side nearer the operator to do what? Looks odd to me because it is plumbed into the tilt lines. Can anyone help this beginner out?
Old RoyG
10-10-2002 18:21:41
 Re: Case 530 CK Loader in reply to RogerM, 10-10-2002 17:52:32
That is the hydroleveling cyl. This cyl displaces oil to keep the bucket level while raising or lowering the loader, Case used this instead of a bunch of mechanical levers to keep the bucket level and not spill dirt over the back of bucket when the loader is raised up all the way.
RogerM
10-10-2002 20:05:49
 Re: Re: Case 530 CK Loader in reply to Old RoyG, 10-10-2002 18:21:41
Is there a flow control on this leveling cylinder or a bypass? My problem is when tilting the bucket backward it puts pressure on the loader pivot. Cracked the loader and had to have it repaired. Don't want this to happen again so am trying to figure out what to do about it. Thanks
Dennis/Ohio
10-12-2002 00:40:58
 Re: Re: Re: Case 530 CK Loader in reply to RogerM, 10-10-2002 20:05:49
Hi, I looked through the hydraulic schmatics and that pressure is normal. I've seen many broken & welded same place as yours. I dont see any relief valves or such. Its a positive oil displacement, move or break. Any pressures on the dump cylinders are on the leveling cylinder. If I'm reading it correctly, the leveling cylinder could be removed and the hoses capped and not have the leveling option. If bucket pivot points etc are binding, that would increase the pressures too. I'm no expert, just the way it appears to me...Dennis.....
KMo
10-11-2002 14:33:31
You probably need a new boss bushing. The one that is welded to the frame post. A new one cost about $130-140 plus installation. I have heard that some people build up the inside of the bushing with weld to take up some of the slack.
I have also heard of removing the old one by using a bi-metal hole saw to cut the weld. I think I would try to grind as much weld off as possible first to save wear on the hole saw. Mine needs to be replaced too.
K-Mo
RogerM
10-12-2002 06:48:06
 Re: Re: Re: Re: Case 530 CK Loader in reply to KMo, 10-11-2002 14:33:31
Thanks for the good info everone.
