1175 case
Ricky
10-14-2002 07:35:58
I am going to look at a 1175 case. What can you tell me about these tractors? The man say the three point will not work but the loader does. What could cause this. Power steering and brakes are weak. Does it have a 540 pto? Anything you can tell will help. Thanks, Ricky
Roger
10-24-2002 01:27:45
 Re: 1175 case in reply to Ricky, 10-14-2002 07:35:58
Ricky, The 1175 has a 451 CID turbo motor which produces 121 horsepower. The PTO should be both 540 and 1000 (speed is changed by removing the PTO shaft and reversing the ends). If the loader works off of the tractor hydraulic pump, then the three point problem is probably linkage or a hydraulic piston.
Ike
10-28-2002 23:05:10
 Re: Re: 1175 case in reply to Roger, 10-24-2002 01:27:45
If you are looking at buying a Case 1175 you won't be disapointed. The 1170 and 1175 were turbo charged and only available as 8 speed mechanical shift tractors. They are bullet proof, try finding one in a salvage yard. Growing up around Case tractors on the farm and now working at the local Case IH dealership I don't know of a more reliable tractor no matter what the color for the 120h.p. rating. I own 2 my dad has 1 a
long with numrous neighbors owning them. Good luck!
