530 CK torque conv. fluid level
GARY B.
10-14-2002 08:56:25
Hi everyone. Should the converter level be checked while unit is running or not running? Also, anyone know what weight oil to use in the oil bath air cleaner? Thanks
Dennis/Ohio
10-17-2002 02:48:28
 Re: 530 CK torque conv. fluid level in reply to GARY B., 10-14-2002 08:56:25
Hi, Mine is a dry clutch but I'm sure I read in the manual that you check your level with engine at idle. The air filter uses same oil as the engine...Dennis....
GARY B.
10-17-2002 14:03:13
 Re: Re: 530 CK torque conv. fluid level in reply to Dennis/Ohio, 10-17-2002 02:48:28
I appreciate the response Dennis, thanks.
