Case 580BCK Hydrostatic Transmission
Bob Petzold
10-16-2002 16:26:34
I am searching for a hydrostatic transmission or hydraulic pumps for a 1973 Case 580BCK.
Roger
10-24-2002 01:11:52
 Re: Case 580BCK Hydrostatic Transmission in reply to Bob Petzold, 10-16-2002 16:26:34
Bob, I have the hydro in my 580B, and I wouldn't part with it for the world. It is one GREAT transmission. It barely worked when I bought the loader/backhoe. Had to have BJ Hydraulics in Delton, Michigan work on the hydro motor. Then, the cam which adjusts the neutral position (right side) rusted and refused to allow the free movement of the internal linkage. I removed the two adjusting bolts, removed the adjuster, cleaned off the rust, greased it well, put it back in, and adjusted for the neutral position. Now, everything works great. If you need some parts, you may want to call BJ Hydraulics.
Jeb Mccranie
10-16-2002 16:54:02
Go down to were the guy asks for the wiring diagram of the case 700 and try some of the websites and phone numbers listed
