Case 1290 oil slick
Jeb Mccraine
10-21-2002 15:12:01
I came out to start up my 1290 the other day and was greeted by a huge oil slick on the side of the tractor. It is seeping out from under the engine block. Not sure if it is oil or diesel.
Is it just a gasket or something more serious. Nothing I hate more than a greasy tractor.
david
10-24-2002 07:00:08
 Re: Case 1290 oil slick in reply to Jeb Mccraine, 10-21-2002 15:12:01
The one consistency I have found with the Case-DB's is that every seal on them leaks. I've had two dozen of them since the mid 70's and, if you plan to keep one, you get really tolerant of oil seeping. That bottom block seal is one of the worst to fix with a new gasket (the silicone works well).
Elmer
10-24-2002 16:42:57
 Re: Re: Case 1290 oil slick in reply to david, 10-24-2002 07:00:08
I always said the David Brown tractor is like a Detroit diesel, if it is not leaking oil something is wrong.
david
10-24-2002 16:51:38
 Re: Re: Re: Case 1290 oil slick in reply to Elmer, 10-24-2002 16:42:57
amen!
But I love'm anyway.
Elmer
10-22-2002 17:04:03
You can put a bead of silicone along the base of the block at the full length. It works for me and is a cheap fix. Otherwise you have to lift the block out and replace the base gaskets.
