220 case garden tractor hydraulics
kevin phillippe
10-23-2002 19:03:48
I was wondering how a person could tap into the hydraulic system for the rear end. I have a snow blade and have a small cylinder that I would like to use to lift and lower it. The drive valve under the tractor looks like it is set up for another control valve. Is this something that was optional. Any input would be helpful. I have not gotten a service manual yet. Maybe something is covered in it.
Thanks
Max
10-23-2002 20:33:10
 Re: 220 case garden tractor hydraulics in reply to kevin phillippe, 10-23-2002 19:03:48
Your unit should have the hydraulic lift, just 'T' into this circuit and then you'll have a rear lift. You may have to wait for one cylinder to bottom out before the one works that your using though. To fix this, use a diverter valve in the circuit so that you can select either the mower lift or the rear cylinder. Remember though that you will be limited to the size of the rear cylinder due to the flow on this circuit. Another idea is to use the hydraulic pto but this can be dangerous due to the higher relief pressures.
