1949 SC pistons
Frank
10-26-2002 18:06:19
Just removed the pistons from SC Case. They don't correspond with the specs. There are no identifying marks on pistons. Measurements are diameter 3.617 in., Top 3 rings width 3/32, oil ring width 3/16. Specs say 3.5 in diam piston, top three rings 1/8 wide, Oil rings 3/16. Pistons have flat top, and there is a empty slot like there should be another ring between the top of the piston and the first ring grove. What are these for? Are these Case pistons or? Frank
Jim M
10-27-2002 02:57:07
 Re: 1949 SC pistons in reply to Frank , 10-26-2002 18:06:19
Sounds like some one has installed a 3 5/8" overbore kit in her at onetime during rebuild and they are worn .008.
