Case 401 diesel
Kevin Baker
10-28-2002 16:00:15
We are looking to buy a Case 401 Diesel and would like to know what the hp of this tractor is. And dfoes the s/n go by the Case 400. If so I have determined this one to be a 1956 model. Help me if I am wrong. The tag says MODEL 401 S/N 8080991
jim
10-29-2002 09:17:44
 Re: Case 401 diesel in reply to Kevin Baker, 10-28-2002 16:00:15
where is it located it makes a differance any thing wrong with it??
Kevin Baker
10-30-2002 20:30:22
 Re: Re: Case 401 diesel in reply to jim, 10-29-2002 09:17:44
We are located in southern VA, and don't know too much except for it runs and has a working JD front end loader on it
Terry Nelson
10-28-2002 17:13:14
I used the Serial Numbers link under Research & Info at this site to check out a Case 411. Power stuff can be researched at the Nebraska test site at:http://tractortestlab.unl.edu/publications.htm.I just looked up a Case 411 (gas). It tested at 53 Belt HP and 44 Drawbar HP. Apparently, there was no rating for pto hp in the earlier tests. The diesel has a few hp more, I believe. Good luck.
Kevin Baker
10-28-2002 21:03:39
 Re: Re: Case 401 diesel in reply to Terry Nelson, 10-28-2002 17:13:14
Does anyone have an idea as to what a 401 diesel is worth???
Pat T
10-29-2002 03:45:39
 Re: Re: Re: Case 401 diesel in reply to Kevin Baker, 10-28-2002 21:03:39
Around here (NW PA), seems like $1800-$2500 depending on condition, if they are running and can do fieldwork, less for ones that need repair$.
Pat
dare
10-30-2002 20:18:08
 Re: Re: Re: Re: Case 401 diesel in reply to Pat T, 10-29-2002 03:45:39
i would sell u 2 of them then
Kevin Baker
10-30-2002 20:28:29
 Re: Re: Re: Re: Re: Case 401 diesel in reply to dare, 10-30-2002 20:18:08
So $500 isn't too much for one that is running and has a JD front end loader on it. Are these pretty good tractors? Thanks for all of your replies
