1958 case 800 case(o)matic trans
ERIC KEPPEN
10-28-2002 22:50:34
what kind of maint can be done. is there a filter somewhere? special oil? adjustments?
caseman-d
10-31-2002 19:45:16
 Re: 1958 case 800 case(o)matic trans in reply to ERIC KEPPEN, 10-28-2002 22:50:34
The 800 has a filter that should be serviced. it is a washable filter, but you can still get new ones from IH. Filter is located on the left side, just right and below of where you add and check your fluid, it's held in with a plate with four bolts. You also might try using Dextron 111 for transmission fluid.
caseman-d
John
10-29-2002 06:09:12
My 400 Case O Matic has 2 filters in the hydraulic system. 1 is in front of the radiator in a cartridge and 1 is under the dash area on the right side of the tractor next to the control valves. I run TCH fluid it is called (transmissions, converters, hydraulics) although I have seen a bunch of different posts on this site regarding this issue.
