Case 1816 Uniloader Clutch
Sam
10-29-2002 10:08:35
I have an 1816 Uni loader. The original motor threw a rod and in turn destroyed the clutch. The clutch split through the housing. Anyway, it is not salvageble. Does anyone know where I could get a used replacement? Is there another clutch off of another loader that may work? I cant afford to spend $700 for a new one. I have a machine shop available so I can modify if need be. (I have a replacement motor already)
brent p.
11-10-2005 17:09:07
 Re: Case 1816 Uniloader Clutch in reply to Sam, 10-29-2002 10:08:35
I too need a replacement clutch for my 1816. The engine is in fine shape so trading up to a bigger one and negating the need for the clutch is a more expensive option than the $700+ clutch. Any suggestions?
RON
03-16-2003 19:51:57
some jacobson commercial mowers had a similar cluch i repaired mine with old parts.
Lloyd
10-29-2002 20:32:25
If you live in a warm climate, you can just install the pully from the 1816B.
Max
10-29-2002 20:15:02
If you put an Onan in it, you can forget the clutch.
