Case 520 hyd.clutch
Mark in OK
10-31-2002 08:10:54
My Pastor has a Case 520 Construction King that the Hydrallic clutch is out on and he would like to know if there is a way to make it a manual clutch?
Mark in Ok
10-31-2002 12:57:18
 Re: case 520 hyd.clutch in reply to Mark in OK, 10-31-2002 08:10:54
Ok I have found out that this is a 530 backhoe not 520 The tractor will drive in what ever gear you are in but if you need to change gears you have to shut the hoe off change gears and restart or idle way down and slip it out of one into another. Can anyone guess at what the problem might be? Clutch bad or could it be out of adjustment?
