Case 430 w/ 420 front loader
don jones
10-31-2002 13:42:37
what would be the maximum lift capable w/ forks mounted on bucket ?
Don L.
11-01-2002 04:37:36
 Re: case 430 w/ 420 front loader in reply to don jones, 10-31-2002 13:42:37
with a ag frt end it won't last a month at 1000 lbs. With a IND solid frt axle and a frt pump, the rear tires full of fluid, wheel weights and a counter weight, it sould do the 2000 lbs range. And that is a heck of alot of weight so far out from the frt axle, it could be VERY DANGEROUS at any hieght.
Don L.
gm
10-31-2002 18:36:51
I think its supposed to be rated at like
2k lbs. OF course, you can probably lift a lot more than that. I think the tires would be the first to go if anything breaks. I would say just keep the front tires inflated
properly and stop lifting if they flatten out too much.
-Greg
