580CK ring gear
Ralph
11-07-2002 09:45:43
I have a 1968 580CK. The teeth for the starter on the torque converter housing are badly worn. Is it possible to replace the ring gear or does the converter housing have to be replaced. If the ring gear can be replaced separately, where can I find one as my manual does not show it as a separate item?
Thanks in advance,
Ralph
DaleIN
11-07-2002 12:55:11
 Re: 580CK ring gear in reply to Ralph, 11-07-2002 09:45:43
Hi Ralph,
The teeth on the TC housing are what engages the internal flywheel teeth to drive the tractor. The starter ring gear is on the outside of the flywheel, p/n G11710, new p/n A182021. Hope this helps, Dale
