1030 leak
Ron
11-07-2002 15:14:57
Dad has tried out the 'new' 1030 and it run good. He told me he has an oil leak at one of the rear brake housings. Is this a seal and is it a major project?
Thanks
bob
11-09-2002 07:58:15
 Re: 1030 leak in reply to Ron, 11-07-2002 15:14:57
not a bad job. I got by without a sleeve. sleeves aren,t that expensiveand not hard to install. If you have a groove maybe you can reinstall seal farther in or out. Have to pull brakes out be sure and catch balls
Don
11-07-2002 20:51:17
Yes there is a seal in there behind the brakes. You may need a sleeve on the shaft also if it is worn. Not a bad job.
