Bad Bad Timing Help
E.R.G.
11-07-2002 16:56:08
I got a 1947 S C Case from a farmer last winter. Did not run. I have started on it. I can not get the timing right. He must have had the gears out some time. Its off one or two teeth. I was wondering if I can take out the Mag and housing it bolts to out instead (Starter side)of taking off the all the front end. Will the Governor come out too? I sure would be thankful for Info. Thanks E.R.G.
Joe in tx
11-08-2002 21:22:47
 Re: Bad Bad Timing Help in reply to E.R.G., 11-07-2002 16:56:08
Can't you just pull the rotor out of the mag and set it like you want and reinstall it. It should be gear driven. I believe a screw holds it in place.
