Is this a case SC??? pics
maplehillfrm,pat
03-18-2006 06:28:04
third party image
hello guys, I have this tractor, I think it is an SC not sure of year, it was in a barn fire a while ago and I cant see any numbers,, I had my sites on another tractor like it and this was going to be for parts , but it fell thru, can you tell me from the pics if it is indeed a SC? thanks pat
maplehillfrm,pat
03-18-2006 08:40:29
 Re: Is this a case SC??? pics in reply to maplehillfrm,pat, 03-18-2006 06:28:04
thanks guys that will help, the tag is gone I will look at the block for numbers I appreciate it, the engine is locked up tight, not sure if it would free up or not , I havent tried yet, thanks for all the info,pat so it would be a tractor that people may need parts for?, that is encouraging, if I have to go that route, pat
todd hamilton
03-18-2006 07:20:41
It is an SC (or was). I own a '44 SC and this one appears to be of that vinatge. If the serial number tag is missing from the dash look on the engine block at the rear near the flange for the flywheel - the number will stamped into the casting. Subtract 4 from the first two digits and you will have the year of production.
lot of parts too
03-18-2006 07:31:42
 Re: Is this a case SC??? pics in reply to todd hamilton, 03-18-2006 07:20:41
Your tractor will have value to someone as there are a lot of usable intact parts - oil pan, internal motor components, clutch, wheel weights, etc. todd hamilton
two fuel caps
03-18-2006 07:26:38
The two caps in the hood would indicate that this tractor once ran on alternate fuel (kerosene, etc). The radiator cap would be at the very front just a couple of inches behind the grill. Todd Hamilton
MGTPa
03-18-2006 06:37:39
Yep, sure looks like a Case SC tractor. Should be a riveted plate with model and serial number on the instrument dashboard. Still lots of good parts on this tractor. May even be able to fix it and get it running again. Is engine stuck? The rear wheel weights are always of good value as someone is always looking for wheel weights.
