Case 300 dash
beanfarmer
11-12-2002 06:33:23
I am currently restoring a Case 300 (312) and the dashboard is gone. I fashoned a piece of metal to cover the hole and include the oil pressure, amemeter, and water temp. gages. Now that the tractor is looking pretty nice, I would like to find a used dash to put back on,to keep it more original. What other model Case tractor used the same type dashboard? I recently saw a Case 800 with one that looked the same as mine,and was wondering if there were more tractors made with the same dashboard. If so, what models are the same so I can ask for them at tractor boneyards. Thanks for any and all help. I hope to have it done in time for a spring show.
Scott
11-21-2002 18:49:41
 Re: Case 300 dash in reply to beanfarmer, 11-12-2002 06:33:23
When you get a new dash, watch to see that the tachometer goes the right direction. I had a 311B with a broken tach cable. When I replaced it, it still didn't work. After some investigation, I figured out that the cable was going the wrong way. Sure enough, when I looked at the picture of the instruments in the owners manual, the tach WAS backwards. Identical in every way except it went the wrong way. I ended up making a reversing gear box for it. When I sold it, the guy told me that the tach probably came off an 800 series or something. Now I can't remember which way was correct. Maybe someone else can help. Clockwise or Counterclockwise?
beanfarmer
11-25-2002 17:32:54
 Re: Re: Case 300 dash in reply to Scott, 11-21-2002 18:49:41
Hi Scott. I got a used dash from Don L.and it seem to work just fine. I still need the cable to drive the M.P.H. side of it, but everything else is o.k. I e-mailed Don L. with my phone number, and he called me the next day. We decided that he had what I needed and I recieved it within two days. Couldn't ask for more than that. I checked the direction of travel of the RPM and MPH and they are clockwise and counterclockwise. I appreciate the tip. Thanks beanfarmer
john
11-14-2002 20:48:40
I have a 1957 case 300 or 320. I am not positive which at the moment. It is my fathers. I just recently started to see if there was anyone to purchase it. It hasn't run in 30 years. If I can't find a buyer for the whole thing I would break it down for parts. I have some pictures of it already if you want me to send them. One is part of the dash and is in tact.
DON L S fan club
11-12-2002 17:51:46
don livingstons email manifold@smig.net phone 507-433-oo73 call in morning 700 central
John
11-12-2002 14:41:29
Are all of the guages in one big dash or each has it's own hole. I am finishing a 411 and I believe Don L has a complete working dash. Get it before the snow flies!
beanfarmer
11-12-2002 19:15:33
 Re: Re: Case 300 dash in reply to John, 11-12-2002 14:41:29
It is one big dash unit, with all the gages inside, plus the engine RPM and MPH needle indicators and all sealed under glass. Thanks! beanfarmer
