500 case
david
11-14-2002 17:59:47
Whats a case 500 with all the tin in tact worth?The exhaust is open to the world so I assume the engine is stuck,but shes all there. Thanks, David
RobertTX
11-15-2002 09:04:58
 Re: 500 case in reply to david, 11-14-2002 17:59:47
A stuck dead one that is basically complete should go for a few hundred. The condition of the tires will be a big factor. If any of them are down, try airing them up before you move it. I have been about 50% successful in being able to re use old flat tires if I can air them before moving. If it gets moved with the tires down, they will probably be trashed.
caseman-d
11-14-2002 18:16:22
500 diesel or the 500B. The 500 diesels (6 cylinders running condition 1500.00 to 2500.00 depending on condition. All depends on your location.
caseman-d
david
11-14-2002 18:31:51
 Re: Re: 500 case in reply to caseman-d, 11-14-2002 18:16:22
N.E. Texas
