530 backfire problem
gm
11-15-2002 10:05:11
Just wondering what all the possible
causes are? It seems to backfire and loose
power more under load, while at idle it
can maintain rpms.
I have tried draining the gas, changing the
coil, spark plugs. The dist rotor seems
a liitle loose, I was thinking maybe the timing
advance springs. Is there a way to test those
without removing the points/condensor and what not. Also, could a flakey condensor
cause this problem?
Any thoughts would be helpful,
-Greg
Dennis/Ohio
11-16-2002 03:51:44
 Re: 530 backfire problem in reply to gm, 11-15-2002 10:05:11
Hi, twopop is probably correct. Just wanted to add you can watch the advance with a timing light. Set initial timing with a test light and set total timing with a timing light at full rpm. Dont have spec's in front of me but can find them if you cant....Dennis....
twopop
11-15-2002 19:27:09
leaking intake valve,cracked dist.cap.
