1952 case tractor
greg
11-17-2002 16:34:31
found one for sale--wanting any info. for this tractor. was told it was a 40hp. has 4 cyl. engine and up draft carb.also has 3 different gear selectors. any type of info would be grateful, are parts easy to find and is it a good tracor for general use around the home.
greg
11-17-2002 16:36:40
 Re: 1952 case tractor in reply to greg, 11-17-2002 16:34:31
model num. on tag reads 351 ----- - and no: 6080641. dont know if it is a vin num. or what.
John H
11-18-2002 16:02:31
 Re: Re: 1952 case tractor in reply to greg, 11-17-2002 16:36:40
If the model number is indeed a 351 you don't have a1952 model. Would like to have more info, IE color, etc, as you might have a 350 which were only built for a short time and are rather rare. The serial number says 1956 and could be one of the first 350's. This series usually came with a four speed transmission and a three speed range giving you twelve forward speeds. Go to the tractor photos and do a search on the Case 300 and see if yours looks like it.
Thanks.
