Case 580D Steering Fluid Leak
Simon
11-19-2002 06:27:13
I have a CASE 580D Backhoe loader. Recently hydraulic fluid starts to leak from out from the center of the steering wheel.
Can someone tell me what to look for or where to start? Appreciate any help. Thanks.
Andrew
11-20-2002 13:10:54
 Re: Case 580D Steering Fluid Leak in reply to Simon, 11-19-2002 06:27:13
you only need to replace seal at the top cover of the orbital valve.a kit just for that is available from any dealer.you can fit it without removing the whole valve.good luck with removing the steering wheel - only hit it from below towards you.failing all that just drill a small hole in the bottom of the column & the oil will run on your feet not your lap!cheers from oz
Max
11-19-2002 20:33:06
The seals are going in the hand pump. You can probly replace the seals with a kit but I never had much luck at that, since the steering operates off the hyd circuit and runs at about 2250 psi with about 6gpm flow.
