1030 case LP
david
11-19-2002 20:48:02
what is the cubic inch of a 1030 case comfort king on propane,whats its value? All tin is straight, rubber is good and she runs. Is the 1030 LP or gas engine a fuel hog or can a fellow afford to feed it? Thanks, David
Jeff
11-20-2002 05:52:04
 Re: 1030 case LP in reply to david, 11-19-2002 20:48:02
wow David, I don't think Case ever made a 1030 lp. they were all diesels. can you get a ser # off this tractor, and how much does the owner want for said tractor?? as for fuel Hog depends on what you plan on using her for, if she's running correct there isn't a case made that is a fuel Hog that's is just part of your cost per acre. got any pics of her??? where did you see such a old girl?? hope this helps.
Roger
11-19-2002 23:13:32
There was no such thing as a 1030 LP or one on gasoline. Case only built them as diesels, 451 cubic inches. If you've seen one, it would have to be one that someone changed over themselves. I've got a 930 gas, LP & diesel, & I don't think any are fuel hogs.
