811 B steering
Richard W
11-20-2002 16:59:04
My 811 B steering is weak. It is very hard to turn. I don't run it much at all. The pump seems to be cavitating and over-flowing. As much as I steer left to right it doesn't help. It also steers better to the left.
John M.
11-21-2002 00:32:06
 Re: 811 B steering in reply to Richard W, 11-20-2002 16:59:04
Richard ... Is the PS fluid coming out of the filter cap air vent? You could have a plugged filter element. If so ,there's probably crud in the system and it should be cleaned out. As the book says, "cleanliness is of utmost importance" Is the fluid coming out of the resevior? There could be air in the system or a stuck check valve. Is the fluid old? If so, drain it, replace the filter and add new ATF Type A equivelent, and bleed the system. Be sure the fan belt is in adjustment.
Richard W
11-20-2002 17:05:27
Anyone know approx. value of this tractor in very good condition in Central Jersey?
