Case Magneto Rotation
Randy
11-25-2002 15:43:22
On a Case SC with Case Mag, is the firing order(rotation) clockwise or counterclockwise on the magneto.
J. Bushue
11-25-2002 16:35:58
 Re: Case Magneto Rotation in reply to Randy, 11-25-2002 15:43:22
Firing order is clockwise,as below: 2 1 4 3
Any suggestion where to purchase good used or new rotor for case sc (magneto) rotor?
RobertTX
11-26-2002 06:59:11
 Re: Re: Case Magneto Rotation in reply to J. Bushue, 11-25-2002 16:35:58
The rotor (or disc as it is called in the parts book ??) seems to be the most common failure in these. The service manual even has a procedure for repairing them. You can rob the contact part from a car or other rotor that is similar size. You fasten it to the rotor with a very small machine screw, No. 2 I think, after drilling and tapping the rotor. I have seen several that have been fixed this way and they have held together. Good luck.
Randy
11-25-2002 17:04:15
Try these places.
Link
Link
Don't know if they can help but you might try them.
