Case 1175 brake problems
chuck
11-29-2002 07:53:31
have no brakes!!!where does master cylinder get its fluid from????
chuck
11-29-2002 08:39:35
 Re: case 1175 brake problems in reply to chuck, 11-29-2002 07:53:31
tractor has sat for 4 yrs. had brakes when parked, have nothing now!!! we have bled brakes & bled them some more & still have nothing!!!!! please help!!!!!
twopop
11-29-2002 17:04:52
 Re: Re: case 1175 brake problems in reply to chuck, 11-29-2002 08:39:35
the master cylinder is located under the hood on the right side just in front of the windshield if it has a cab.it has its own tank,so it is filled from the top,and uses brake fluid,not hyd. fluid
chuck
11-29-2002 20:24:16
 Re: Re: Re: case 1175 brake problems in reply to twopop, 11-29-2002 17:04:52
the case that I own doesn't have a cab i am sure that it is hyd. fluid but does it come from the center line on the master cylinder or from the valve on the top? does the tractor need to be running to get fluid or not?
twopop
11-29-2002 21:01:18
 Re: Re: Re: Re: case 1175 brake problems in reply to chuck, 11-29-2002 20:24:16
the 1175 i worked on took brake fluid into the top of the master cylinder.i dont know much more about them
