Case DC/ DC-3? Whats the difference?
Tom Bush
11-30-2002 17:11:11
Whats the difference between a "DC" and A "DC-3"?
Don R
11-30-2002 17:45:01
 Re: Case DC/ DC-3? Whats the difference? in reply to Tom Bush, 11-30-2002 17:11:11
Tom,
A DC is the same tractor as a DC3. The numbers just determine the wheel configuration. The D is a standard tread with non-adjustable rear and front axles with 26 inch rear tires. The DC3 is a row crop tractor with adjustable rear axles and either adjustable wide front or narrow front wheels. A DC4 is a row crop tractor with adjustable rear axles and non adjustable front axles. Both the DC3 and DC4 had 38 inch rear tires.
Tom Bush
11-30-2002 18:55:57
 Re: Re: Case DC/ DC-3? Whats the difference? in reply to Don R, 11-30-2002 17:45:01
Don, Thanks for the infoI didn't know if it was related to motor size or what,My Grandfather had one and I wasn't exactly sure what I was looking for.Thanks again for the answers..Oh!do you know if the rear rims from an International will workon my "DC" or not? Tom
Mike Schotte
11-30-2002 20:12:19
 Re: Re: Re: Case DC/ DC-3? Whats the difference? in reply to Tom Bush, 11-30-2002 18:55:57
Tom,
I've currently got a set of 12.4X38's and rims from a Farmall H mounted on my '49 DC-3, so they will fit.
The alignment lugs are a different style, but they still fit inside the slot in the wheel hub.
-Schotte
Steve-MN
12-01-2002 07:18:22
 Re: Re: Re: Re: Case DC/ DC-3? Whats the difference? in reply to Mike Schotte, 11-30-2002 20:12:19
Mike,
Thanks for the info on Don L. Sounds like a great contact! My hotmail crashed right after I read your message so I couldn't return the thanks from there. Hopefully you'll get this.
Thanks,
Steve
