1200 not charging
Ron T
12-01-2002 09:19:14
Last summer my DB 1200 quit charging and while not running it will run the battery down overnight. I am thinking this might be the voltage regulator under the dashboard. I replaced the generator two years ago but a mechanic says I should take the generator off and check it out before replacing the voltage regulator. I don't suspect the generator as much because it runs the battery down when it is turned off. should I take his advice or just go for a new regulator? I understand they are real pricey.
wim van houtte
11-16-2006 14:14:13
 Re: 1200 not charging in reply to Ron T, 12-01-2002 09:19:14
Hello From Belgium!
a friend gave me a David Brown Case 1200 tractor, free,
but there is some work on it.
could someone please tell me the type of battery i need ?
i don't know if the battery charger is still working.
Thanks, Wim
Jimc
12-01-2002 15:57:22
New lucas type rb108 voltage regulators are at Link and are priced at £14 or say $20 .This is`nt expensive.
Allan
12-01-2002 15:31:13
This is a generator right! not an alternator. On a generator almost the only thing that could kill the battery overnight would be the cutout stuck shut. ( it's a part of the regulator). Take the fan belt off and, with a charged battery in it see if the generator is trying to motor. (you may ve to spin it by hand to tell). If it is , then for sure the problem is in the regulator.
Elmer
12-01-2002 12:40:11
Convert it over to a Delco alternator.
Pat T
12-01-2002 15:20:25
 Re: Re: 1200 not charging in reply to Elmer, 12-01-2002 12:40:11
Amen to that, Elmer, I did our 990 and 1200 5 years ago and it was the best thing I ever did to those tractors. So nice to hit the key and know it's going to rollover for you!!
Pat
Elmer
12-01-2002 16:49:13
 Re: Re: Re: 1200 not charging in reply to Pat T, 12-01-2002 15:20:25
The generator only put up about 15 amps at best and when using the tractor to blow the laneway out it barely charges the battery up after a cold start. The alternator will put up 43 and does the job just fine.
Jeb Mccranie
12-01-2002 12:06:22
My 1290 did the same thing. I had to take it apart and install new brushes on the alternator. If you operate your tractor in a lot of dust, look for alternator trouble.
