Case 450 Dozer with 207 Diesel End of 1978 model year
Kevin
12-04-2002 18:05:46
This is probably more of a diesel engine prob. but my Case Dozer is smoking. Works great, pushes fine, I used it all summer and it always smokes white. On start up, when warm, and when cooling down. It uses a little oil but nothing excessive. No water seen in the oil. Coolant is fine. Any thoughts.
Thanks
kevin
12-13-2002 20:43:02
 Re: Case 450 Dozer with 207 Diesel End of 1978 model year in reply to Kevin, 12-04-2002 18:05:46
check your injectors
Max
12-04-2002 20:41:01
That was normal for that year for they started the emissions thing in 76 and then in 79 they realized the white smoke was more polluting than the black so the injection pump was changed again or so I was told back then in 79. You might want to check the timing on the pump though and make sure its set properly. I used to know what the running timing was set at but its been a while since I did that and I forgot it, besides it takes one of them fancy plastic windows to take the place of the metal cover on the side of the pump. You might also check you air filter, Case engines were always notorious for black exhaust smoke being the fuel filter and white smoke being the air filter.
