830 case-o-matic
sheiserman
12-06-2002 16:37:56
It is very hard to move lever from converter to direct drive. It works fine when it gets there, but just about need a crowbar to get into direct drive. Anybody else have this problem?
brian in ky
12-08-2002 07:38:13
 Re: 830 case-o-matic in reply to sheiserman, 12-06-2002 16:37:56
You should be able to flip the leaver with one finger. If yours is a case-o-matic check for bonding of the linkage under the dash
brian in ky
Glenn
12-20-2002 19:06:45
 Re: Re: 830 case-o-matic in reply to brian in ky, 12-08-2002 07:38:13
also,check your valves.(caseO-matic valves)
sheiserman
12-08-2002 18:29:40
I'll give it a look. Thanks
