Case SC alternator
Zach Martynski
12-08-2002 07:47:29
Where do the wires go from the alternator, to the amp gauge and back to the battery or what???
whip
12-09-2002 16:39:38
 Re: Case SC alternator in reply to Zach Martynski, 12-08-2002 07:47:29
Zach , If memory serves me right ,you need to run your wire that comes from the battery to the amp gauge then to the alternator. Hope this helps .
Whip
Larry
12-08-2002 15:04:41
Maybe this will help.
Mike Schotte
12-08-2002 08:30:26
See if you can read this. If not, I'll e-mail you a larger copy.
">Link
-Schotte
Whoops...
12-08-2002 09:00:48
 Re: Re: Case SC alternator in reply to Mike Schotte, 12-08-2002 08:30:26
I forgot you said "alternator" and not "generator". Obviously, that wiring diagram is for the original wiring layout and 6V battery.
Someone else will have to help you with the 12V conversion wiring.
-Schotte
