1030 seat
Tod
12-09-2002 07:47:02
How do I remove the seat and center platform section on a 1030? I need to do some cleanup work and adjust the safety switch on the range lever. thanks!
inCASEyougetstuck
07-11-2006 11:49:28
 Re: 1030 seat in reply to Tod, 12-09-2002 07:47:02
is it a metal or a soft seat??
Pat
12-09-2002 15:25:02
Hello! Your seat suspension is bolted to a casting that is bolted to the platform. remove the bolts on casting, and lift the seat off. The center platform panel is retained by recessed allen head screws. These screws are usally rusted and will snap off!!! Once the panel is removed you will access to your safety switch.
tod
12-16-2002 07:39:10
 Re: Re: 1030 seat in reply to Pat, 12-09-2002 15:25:02
thanks - that did the trick - my bolts came out without snapping and luckily the nuts were still welded onto that bracket
