Case 1816 uniloader
dan
12-09-2002 21:49:27
My left side hydro works great the right side has about a 3 second delay then whines and starts to work about half power. I replaced all the hoses to the right pump and still not working. Anyone have any ideas.
Richard in W V.
12-14-2002 08:44:42
 Re: case 1816 uniloader in reply to dan, 12-09-2002 21:49:27
Dan pull the cover off on that side and see if the clutchs are what are doing the squaling.i`m not sure if it is set up like the 1500 series.
Max
12-10-2002 06:14:26
Check the drive belt for condition and correct tension. Have you checked the pressures yet? could be a pump or motor, that why I asked about the pressures first.
dan
12-11-2002 16:48:52
 Re: Re: case 1816 uniloader in reply to Max, 12-10-2002 06:14:26
Havent checked the pressures yet I had the pump apart and a mechanic looked at it and said it looked good. I dont know
