CASE 530 CK
ROD
12-14-2002 08:16:36
I AM LOOKING FOR PARTS FOR A 4 SPD DUAL RANGE TRANSMISSION ON A CASE 530CK.I NEED A SHUTTLE OUTPUT GEAR,SYNCRONIZER UNIT, AND POSSABLY AN INPUT SHAFT.ANY INFORMATION WOULD BE APPRECIATED.
Dennis/Ohio
12-17-2002 17:23:38
 Re: CASE 530 CK in reply to ROD, 12-14-2002 08:16:36
Hi, This is a dry clutch if I'm understanding correctly. I'm thinking your gears could be the same as many older Utility tractors. The casting number on the left side of 4 speed case is G1096? My opinion: Have the part numbers for what you need is the best way to look for parts....Dennis...
