Case 885 slow hydrolic lift
Barry Kniceley
03-28-1999 19:08:14
1975 case 885 farm tractoc hyd. lifting slow and not very strong. I think that there may be a blockage in the system. Looking for a parts break down of the hyd.pump or of the system on how it may work. I have change the fliud every spring before getting ready for the summer work thanks Barry
Elmer
03-29-1999 05:11:45
 Re: case 885 slow hydrolic lift in reply to Barry Kniceley, 03-28-1999 19:08:14
Sure sounds like a bad pump. When you changed the trans fluid did you change the filter and clean the bypass screen. Alot of times i have seen people take out the hydraulic filter and replace it, but don't change over the bypass screen.
