CASE 530CK STEERING PUMP
MIKE A
12-15-2002 19:18:14
I HAVE POWER STEERING PUMP ON A 1969 530CK THAT IS BLOWING OIL OUT THE VENT HOLE IN THE CAP. PUMP IS NOT OVER FULL ON OIL. ANYONE HAVE ANY IDEAS?
scottAR
12-16-2002 19:26:48
 Re: CASE 530CK STEERING PUMP in reply to MIKE A, 12-15-2002 19:18:14
I had one do that. Changed from hydraulic oil to ATF and it quit doing that.
klyde
12-16-2002 09:57:40
did you check the filter????
MIKE A.
12-17-2002 22:15:24
 Re: Re: CASE 530CK STEERING PUMP in reply to klyde, 12-16-2002 09:57:40
I HAVE NOT CHECKED THE FILTER. I WILL CHANGE THE FILTER AND OIL AND SEE WHAT HAPPENS.
THANK YOU FOR YOUR SUGGESTIONS
GeoMo
12-16-2002 05:38:06
I have as 830 that blew out the cap and did not work well after being used, tank got hot.
I replace the check valve and corrected problem.
