46CASE belt pully gasket tolerance
Ted A
12-23-2002 09:29:49
Can anyone tell me what kind of gasket material to make the belt pully gasket out of. The seals are leaking and I can no longer get seals or gaskets for this job from the CASE dealer. I have given them the numbers from the parts catalog and they indicate they are no longer available. Anyway, I have an address for a local seal company that the delaer indicates should be able to match up the seals and I think I can make the gaskets OK but the service manual indicates an adsustment to make things mesh properly. The adjustment does not look straigh forward and might require opening up things even more. SO... I would like to match the gasket material and thickness as close as possible and avaid making the adjustment. Thanks
