Brake pedal lock
Randy
12-23-2002 18:23:45
On my 1949 Case SC the brake locks are so tight it takes a hammer to move them. Before I fix them I wondered how tight they should be. Anybody know if they should be loose are stiff to move?
Randy
C. Amick
12-27-2002 09:52:40
 Re: Brake pedal lock in reply to Randy, 12-23-2002 18:23:45
Be careful hammering on them. You will break the lever off. One of mine is broken off. Let them soak for a while with some P.B. Blaster on them.
Scott KY
12-23-2002 18:56:22
The locks should move freely. Yours are probably rusted up. See if you can get them off and clean them up and you should be ok.
Randy
12-23-2002 19:08:50
 Re: Re: Brake pedal lock in reply to Scott KY, 12-23-2002 18:56:22
Thanks Scott for the quick answer.
Randy
