Case L, LA Valve size
Texas Red
12-24-2002 07:09:24
Can anyone tell me if the valves in a CASE L Head and a LA Head will swap out? Thanks for the help TR
Bill Hires
12-25-2002 06:41:03
 Re: Case L, LA Valve size in reply to Texas Red, 12-24-2002 07:09:24
The "L" parts book gives the exhaust and intake valve part number as 06048AB. The "LA" parts book gives the same number, 06048AB for the exhaust valves. The "LA" book lists stellite and LP valves, also. The "LA" intake valve part number is 01156AB1. The I & T manual gives the following sizes for the "L" and "LA" valves, guide inside diameter .4375-.4385, valve stem diametral clearance .0035-0055, valve spring free length 31/8" and tension 88-96 lbs. @ 21/4". I beleive the valevs will fit either head. We have both an "L" and "LA", but have not checked on exchanging valves.
Texas Red
12-25-2002 11:42:43
 Re: Re: Case L, LA Valve size in reply to Bill Hires, 12-25-2002 06:41:03
Thanks you very much for the help. i am going to need to replace two valves on my la head and my uncle has some good valves in an old L head. Thanks again TR
